Freak
03 rx1 turbo. I should know this but Ive been out of the game for a couple years. Motor rebuilt and back together. running heat cycles to break in. after revving up to say 5000rpm it wont idle back down. have to use choke to get it back down to idle rpm. Im assuming air leak of some sort? Anyone point me to the quick fix or just need to go through everything? tia
offside
Hi
I would look at the TPS sensor
Sterling
- Nov 4, 2005
Carb synch maybe......Sticky throttle cable.....
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
I bet throttle blades do not close back to idle
Freak said:03 rx1 turbo. I should know this but Ive been out of the game for a couple years. Motor rebuilt and back together. running heat cycles to break in. after revving up to say 5000rpm it wont idle back down. have to use choke to get it back down to idle rpm. Im assuming air leak of some sort? Anyone point me to the quick fix or just need to go through everything? tia
I think your right it sounds like a vacume leak on all cylinders, is the A/F lean when it is idled up. You can try spaying some WD40 around it to track the leak
Ya got some head work done to that monkey? I hope you remenber how to hang on to it.
promod63
- Mar 14, 2004
- Blackfoot, Idaho
- www.thunderracingengines.com
Dave didn't you say you had a nitrous back fire? Check your throttle blades , they are most likely bent.
Freak
promod63 said:Dave didn't you say you had a nitrous back fire? Check your throttle blades , they are most likely bent.
blades are you talking slides or butterflies or???
promod63
- Mar 14, 2004
- Blackfoot, Idaho
Butterflies or shafts, slides will only hold the needle up. The nitrous explosion could have bent them and allow more air into the engine at idle.
