mountain addiction gas tank
Gibby
Jackson, Michigan
Website
www.fitzgibbonstruck.com
http://www.klymazzation.com/snowmobile- ... rack-rack/
http://www.netsleds.com/gear/index.php? ... ts_id=1065
i was wondering if anyone has used this and what kind of quality they are. Also if anyone that has seen the XTX if I would be able to fit 1 of the 1.3 gallon tanks on the tunnel without any mods to the tail light or exhaust, i can not find dimensions of the gas tank anywhere to see the exact size
the other one i am looking at is this
http://www.craiggerbuilt.com/shop/html/ ... GYG2-.html
but i think i would have to move the tail light and put a turn out on the exhaust
Any info would help
Gibby
That first one is slick.... wonder if it would fit the XTX? anyone????? gives you the same capacity as the trail tank for way less cost and work....
An exhaust turnout is not expensive and easy to install. If what you want to do requires a turnout, I wouldn't hesitate. Moving the tail light is a little more work because of the need to splice wires, but if I can do it, anyone can.
I have the tour buddy on mine and it works great, but had the aftermarket trail tank been available, I would have purchased it in a heart beat. If I was starting from scratch I'd put on the aftermarket tank, exhaust turnout, relocate the tail light and a small rack that could be used for either a small carry bag or gas can.
