fubar8182
- Nov 5, 2014
- 02 viper / 13 nytro txt 1.75
Alright, ya I am just gotta straighten out the tail light on the back and maybe raise the MA rails a little, but it should work, I'm hoping to be able to do that soon, just waiting for the store to get the kit in.
Matthew457
Any luck with that? I am headed up to qc in 2 weeks I have a 2013 nytro SC mpi stage 1 and going to need the gas. Was wondering what u did with taillight etc pics?
Anythong u can do to help thanks
fubar8182
- Nov 5, 2014
fubar8182
- Nov 5, 2014
Matthew457
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
I just ended up putting them on normal and making a deflector with a piece of aluminumMatthew457
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
To see stuff I did, click on my account and go to "postings" and check under anything I have posted to do with ma gas cansMatthew457
fubar8182
- Nov 5, 2014
Yes I saw those good job. Did u have to move the taillight? If so did u have enuff cable and was it bolted , did I have to drill holes ? I only ask because I don't have my sled with me going to have to do this TrailerTo see stuff I did, click on my account and go to "postings" and check under anything I have posted to do with ma gas cans
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Yes, moved tail light to the reflector holes on the back reflector because the holes line up with the tail light holes. Added a bit of wire, put fuel line around the wire under the tunnel and have not had one problem. Drilled a whole for the wire to go into the tunnel, just like it up with where the wire comes out when u put the tail light where the back reflector is.Yes I saw those good job. Did u have to move the taillight? If so did u have enuff cable and was it bolted , did I have to drill holes ? I only ask because I don't have my sled with me going to have to do this Trailer
fubar8182
- Nov 5, 2014
Ok. Great what gage wire was it?Yes, moved tail light to the reflector holes on the back reflector because the holes line up with the tail light holes. Added a bit of wire, put fuel line around the wire under the tunnel and have not had one problem. Drilled a whole for the wire to go into the tunnel, just like it up with where the wire comes out when u put the tail light where the back reflector is.
sprintcat
- Jan 13, 2009
- Rumford Rhode Island
- Nytro xtx
Fuel line ? This kit connects to the fuel tank ?
fubar8182
- Nov 5, 2014
No the wire u addedFuel line ? This kit connects to the fuel tank ?
sprintcat
- Jan 13, 2009
- Nytro xtx
Okay I understand. Thanks
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Not sure, just found some wire laying around, it was a lot thicker then the wire on the sled but it worked goodOk. Great what gage wire was it?
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
LolFuel line ? This kit connects to the fuel tank ?
fubar8182
- Nov 5, 2014
Ok great thanks I'll give it a shotNot sure, just found some wire laying around, it was a lot thicker then the wire on the sled but it worked good
