MOUNTAIN LITE IS IN, ANY MOD SUGGESTIONS!!
sledneck84
Corscia SD
Just got the call,picking it up on saturday. Just curious what guys are doing out there for mods, it's for the wife and ditch bangin for me so i don't need a turbo.Got a modded Mountain Max for the mountains. Any info appreciated. Plan on painting the ugly grey side panels for sure.
you could do the D&D bulleyes vents in the airbox and gain 3-4hp throughout the power band...
also here is a big one and very easy. remove the bolts from the pod bracket, drop the bracket down so the top hole on the pod bracket is lined up with the bottom hole on the riser neck. secure it with the same hardware, leaving the bottom pod bracket hole open. then build yourself a small C type clamp out of steel, and bolt that to the lowest windshield holes on the riser neck, this secures the bottom of the pod. you've dropped your pod a couple of inches for almost zero dollar. i'll see if i can dig up some pics.
where you see the bolts on the riser neck in the picture, that is where the C bracket mounts up to secure the bottom part of the stock pod bracket.
(note the C bracket is not in the above picture. pm me if you want pics)
Thanks,i'll have to do those. I was wondering if that pod would be to high. If it's that easy i'll relocate it. Thanks again.
Phazed-Coug said:
nice work on the pod...
JP watch that throttle cable carefully.. it'll rub if your not
careful.
thanks.. been keeping an eye on it. part of the pre-ride check. but it seems fine and i have 12 days out on the mtn lite.. gonna keep an eye on it for sure
sled
Well we just picked one of these bad boys up for my little bro and im wondering whats the best hp gainers? Were going to get a new tunnel extension made cause the stocker looks heavy.
