Mountain skis on 07 Attak??
djs41382
Hello,
This is my first post so take it easy on me. I picked up on 07 Attak and would like to put the skiis from a Mountain Apex on, is this a simple bolt on procedure? Or do you think that they will not fit?
Thank You
i believe they bolt right on..... lots of guys have put them on their newer yamis.....
There is a longer bolt and some shims to add or take off the mountain apex other than that they will bolt right on.
I put mtn skis on my 06' RTX and like them. They are cheaper then buying aftermarket and woked well this year. I run 8" bergstrom triples on them as well.
I have run the Mtn skis from day one with Studboy deuce bars. Zero darting in any conditions. I may try the Bergstrom triples next time. Do they dart and are they easy steering?
I have the mtn skis on mine, - they are better floatation but with the stock carbides, darting is bad.
Ran mountain skis on some trail with skis shimmed and was good with stock carbides.Handled quite good.Just about no darting.
I don't have a darting problem at all. I did the shim trick as well.
