Anything that I would have to do for them to fit, such as changing the rubber? These are Yamaha skis by the way. Also, any pros/cons to putting mountain skis on an Attak?
Thanks for the tips!!
Dane
Dane
acesfan05
You don't need to buy any extra parts to fit the Yamaha mountain skis on an Attak.
My brother put them on his Attak and they have been a huge improvement over the stock skis.
Will
Will
favarcat
You need 4 collars, 2 longer mounting bolts, and 2 bushings to mount the skis. They work great with studboy deuce bars.
I have them on mine and I'm swapping them out for Powderhounds. They float pretty good, but the same old darting problem....
favarcat said:You need 4 collars, 2 longer mounting bolts, and 2 bushings to mount the skis. They work great with studboy deuce bars.
What are the collars?
favarcat
Tal said:I have them on mine and I'm swapping them out for Powderhounds. They float pretty good, but the same old darting problem....
Mountain skiis shimmed with deuce bars and ZERO darting.
favarcat
I believe these are the part numbers, but check with your dealer to make sure.
90387-16013-00 COLLAR x 4
90387-10036-00 COLLAR x 2
90105-10106-00 BOLT, FLANGE x 2
Thanx for the info Favarcat.
AllagashX
i just got my 08 ltx with simmons ski's its works real good.
attakred06
you guys have a lot a money to spend on all kind of ski
you keep your yam ski and you put snowtraker on it 169.00cdn and they will go 15000 klm at least no more darting with f1 control your after market ski buddies will eat your snow dust
no matter what they ride!!!!!! snowtraker.ca i belive....
no matter what they ride!!!!!! snowtraker.ca i belive....Similar threads
