thobkirk
I just ordered a set of mountain skis off a 09 nytro for my warrior. I plan on installing them when I go out west. Does anyone know how will they act on trail? I am debating on leaving them on all the time and getting rid of the stock skis.
they act fine on the trail. the keels are deeper than stock so they will sink in and bite in looser conditions than stock. make shure you get the spindle tubes and spacers as if you just shim it with washers, you can break the bolt and loose the ski on sharp impacts. youngest brother learned that one the hard way.
thobkirk
Thanks for the input. Is the saddle wider or can I use my current ski hardware?
you can re-use your stock ski rubber with a shim as per the tec pages and the carbide inserts and ski loops are the same.
the mountain ski is wider than the stock ski so the tube in the end of the spindle is too short.
parts you need are
4 of 90387-16013-00 collar
2 of 90387-10036-00 tube for spindle
2 of 90105-10106-00 bolt
2 of 95607-10200-00 nut
parts you need are
