Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
I mounted mine yesterday like MXD has his done. I've got 30 plus years riding now and I have never rolled yet. I usually try to stay away from potentially ugly situations.....but of course now that I have said that I will probably flip it tomorrow. Now I just have to wait for my power cable to arrive. Are those power cables reduced voltage? I have a cigarette plug as well as the open ended wiring harness coming. I was hoping to hardwire it in.
MS-310
I just wired mine in with a cig plug in....Works Great.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
Yes I can do that as well but I have other use for the 12 volt outlet on the sled so I would prefer to hardwire it. Then it would be powered all the time
jlemieu1
- Feb 7, 2005
- Rosemount, MN
- 14 Viper LTX SE, 14 Viper LTX
Just this last weekend I saw a guy at the Hawkins warming shack(WI) that powered his GPS with clips to jumper cable terminals. Of course it was routed below the panel and through the neck. It was a pretty slick setup. He used the Ram handlebar mount.
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
That is what I plan to do whenever my cables arrive
bottlerocket
So is it safe to say that the marine mount comes with the 276C or do you have to purchase a marine mount? Thanks
CaptCaper
- Jan 1, 2007
- Northern N.H.
cire said:So is it safe to say that the marine mount comes with the 276C or do you have to purchase a marine mount? Thanks
I'd purchase one from Ram Mounts. They are stronger.
bottlerocket
Is it just called a marine mount? I have been on the Ram website awhile back and it seemed confusing with arm lenghts and such. Thanks
august
Touratech GPS mount
If you want the very best go Touratech...a little pricey but a good product. They have a few different models for the 276c, i had the locking one and it worked great. The mounts have actual suspension for the GPS units so they don't get rattled so much. Pretty slick setup.
http://www.touratech-usa.com/shop/show. ... GPS13D366C
bankershrs
- Sep 19, 2008
- Roscoe, IL
- 2017 Yamaha Sidewinder RTX LE
August, using the Touratech, where did you mount the GPS on the sled? Looks like it is set up more for a handlebar mount but I see most other mounts going off the riser bar.
bottlerocket
Looks like it is a flat plate on rubber mounts. Looks complicated for a gps mount !
Phazernut
- Nov 2, 2007
- 04 Viper ER.
96 V-Max 4
Looks like something from my dentist's office. It scares me
