Mounting Plate Pattern ZX2 / Apex 07 RTX
1litre
Crystal Falls, MI
can anyone help me out with a template / Drawing to mount a ZX2 skid in to my 07 Apex RTX. I purchased the ZX2 from another TY member who had it mounted in a 07 Attack. He is going to send me the mounting plates off of his Attack. Can I modify the mounting plates to fit w/o reinventing the wheel?
Where can I find prices / part numbers, installation instructions for the 07 Apex RTX mounting kit?I have searched A D Boivin's site and can't seem to find the correct PDF.
Thanks for any advice and info.
Does the RTX skid use the same front mount hole as the monoshock skid?
The mount kit I bought came specifc for the Monoshock equiped sled. Using the existing front mount hole for the mono you bolted the mount plate to the tunnel and then using the holes on the mount plate you drill out the holes in your tunnel for the zx2. If the RTX does not use the same front mount holes you will be guessing where to mount that plate.
Might be easier to just call AD Boivin and get the correct mount kit.
I moved my mount kit from the my RX1 to the apex mono and just measured off the driveshaft to locate it correctly. The mounting kits are too much money if you already have one to work with.
Use the universale directions i posted and measure back from the drive shaft to the first hole position and that is where you plate will go.
