MPI Apex codes
jw440/800
Upstate NY
Need some help getting some error codes straightened out. I am getting error 12 and error 46, 12 is no normal signal received from crankshaft position sensor. 46 is power supply to FI is not normal. We just put a new gel battery and a new stator in. What do I need to do to fix these codes and how do I go about it?
Please help!!!!!!
I just tested stator and everything is good, I unplugged the rb3 and turned it over to try to clear the code. I reinstalled the rb3 and the codes are still their. I tested the stator that I took out and the it was fine :o|
Any ideas????
I'm throwing in the white flag :o| Its going to Dave a Hurricane Performance tuesday, I know it will get done right there. :Rockon:
Well its been a battle but Dave at Hurricane got it all figured out. The problem was a bad rapid bike (which only had about 250miles on it :o|) once Dave got that figured out, it was still "chugging" at 5000rpm / 1lbs of boost. He ended up tuning it and trying to get it out but it was still there no matter what he did. Dave ended up finding out it was a bad map sensor :o|
Dave is a standup guy and is very very good at what he does. I look forward to making a new monster with him this summer. 1 apex motor and one nytro chassis :Rockon: its going to be a killer
Thanks again Dave
