kinger
Do most of you guys route the breather pointing at the coolant tanks like MPI suggests and have it spray oil mist all over that area?
Anyway to clean it up so its not constantly getting the electronics, brake, etc covered in spray? Its not bad after 1000 miles this sled has a film on everything that will easily clean up with some degreaser and a hose but seems like a wierd deal. Thanks!
SPEED
I went to an auto parts store and put a small breather filter on ,wor ked fine
kinger
Did you leave the plug like thing that came with it installed from MPI as well or remove that?
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
REMOVE IT !
millstreet
- Dec 6, 2005
- doylestown, pa and old forge, ny
- current - 2018 Sidewinder ltx-le 50th
Ted'll sell you a neat little box sorta thing that solves that issue - or you can just wipe it off or not - then you sled will look like mine
Note the oil spouge beneath the breather tube
I wrapped a small shop towel on mine. Should we take that plug out?? Wounder why they put it in?? Anyone???
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
millstreet
- Dec 6, 2005
Nice!
Colorado Yamaha
- Sep 4, 2005
- Colorado Springs
- 2010 Nytro MTX - MCX
Case Breather
Jannetty sells a kit for the RX's - like the guy with the Nytro did, aluminum box, lines, breather - return line.
We use the little blue automotive type filters (looks like 2" mini chrome K&N filters) for $10 - then wrap it with a micro fiber cloth cut down.
I use to use just a rag over the MPI insert and then covered that with a plastic baggy.
kinger
Good designs guys! I'll pick one and do something about it before next year. Thanks!
bklynantnee
Isnt the plug from mpi a filter? seems very restrictive. do they want that resistance? doesnt seem right.
machzrobbie
I routed the hose to the nose of the sled on the left side right beside the S/C oil tank - its alot easier to clean up there - just take the nose cone off and wipe it up, I leave a shop rag right under it and it soaks up most of the oil
thamax
looks like you spare belt blew the cords out
