wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
Was told by my dealer that the fuel injector does not supply enough fuel for this mod and will cook engine. What do they do to moodify fuel system ? do they ran an extra fuel injector. Something about stock injector already at 85 % of operating capacity, and not good to run it any higher
heath@mpi
- Aug 20, 2008
stage 1 supercharger @ 7-8 psi is max for your fuel injectors at your elevation
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I run a stage 1 at 10-11 psi and ran out of fuel, added a $80 hi flo full pump and have more then enough fuel now, still trying to lean it back out.
My engine is shimmed for 10:1 compression. This is for a apex.
heath@mpi
- Aug 20, 2008
I just noticed this is a Apex sorry. Apex has much larger injectors then the Nytro which i labeled
wkeggenhoff
- Dec 20, 2007
APEX HEAD SHIM
DID YOU SHIM THE MOTOR YOURSELF OR DID THE DEALER DO IT. WHAT DO THEY CHARGE FOR THIS SERVICE ? I KNOW ALLEN ULMER SUPPLIES A SUPPLIMENTARY FUEL PUMP i BELIEVE FOR STAGE 2, DONT KNOW IF IT IS USED ON STAGE 1 OR NOT.
DC5
With a larger fuel pump, the injectors are maxed at 14lbs. They will run comfortably at 10-11lbs with the larger pump. I wouldn't use the stock pump over 7lbs.
kinger
- Jan 17, 2005
- Clear Lake, IA
Ulmer did my shim...twice just cause he was practicing
JK
- 7K
