Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
ive been reading Lot of people are going with gearing there turbo vipers for more top end.
What gearing combinations are people using , and how much gains are you getting?
Studroes144
- Oct 30, 2013
Ltx se, stock 24/50 gearing all I could pull was 109 mph, switched to 21/41 gearing (stock xtx gears and 86 pitch chain) and ran it up to 116 mph, and wasn't shifted out yet. The sled gained everywhere with the taller gearing.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
That sounds like the way to go. Did you keep the original chain?Ltx se, stock 24/50 gearing all I could pull was 109 mph, switched to 21/41 gearing (stock xtx gears and 86 pitch chain) and ran it up to 116 mph, and wasn't shifted out yet. The sled gained everywhere with the taller gearing.
Studroes144
- Oct 30, 2013
No I ordered both gears and the chain right through yamaha, total it came to like $150 for everything, 1000 miles on the new gears and chain and it works great. It's just the stock chain and gears for the xtx viper
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I didn't know the xtx would be geared taller then an ltx.No I ordered both gears and the chain right through yamaha, total it came to like $150 for everything, 1000 miles on the new gears and chain and it works great. It's just the stock chain and gears for the xtx viper
Thanks for the info
Studroes144
- Oct 30, 2013
The xtx uses 8 tooth drivers, ltx uses 9 tooth drivers, so that's where the difference in gearing comes from. The xtx and ltx theoretical speeds are actually within 1 mph of each other, but put the taller xtx gearing on an ltx or rtx and you'll be all set to run some good speeds.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Hey Barry do you think there would be any gains from a none turbo with clutching and exhaust on a ltxse with your gear and chain set up or not enough hp?The xtx uses 8 tooth drivers, ltx uses 9 tooth drivers, so that's where the difference in gearing comes from. The xtx and ltx theoretical speeds are actually within 1 mph of each other, but put the taller xtx gearing on an ltx or rtx and you'll be all set to run some good speeds.
Studroes144
- Oct 30, 2013
Without actually doing it there's no real way to know for sure, but I'd love to see someone try it! With mine I noticed no difference at all in low-mid range pull, clutching stayed the same, only things I noticed that really stuck out were obviously much higher top speed but also it was much easier to maintain traction on a hard launch, and to me that's almost something that an n/a viper could benefit from as much or more so than a turbo. Granted the turbo really has no noticeable lag on a launch, but the n/a viper makes a ton of power just instantly so it's very easy to just blow the track out, taller gearing seems to have helped my sled in that area.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I went with 21-41 also. Ran it all year. I was going to change my gearing even if I didn't turbo charge it. Top speed was not the reason I did it. My thought was to "calm" the sled down a little on the bottom and out of corners. One benefit was I can get 16.5 mpg if I want.
yzf1999
- Dec 25, 2006
- Bloomington, Illinois
- 2015 Yamaha SR Viper LTX SE
I'm seriously thinking of changing the gearing of my 2015 LTX SE to the XTX gearing. I keep reading that stock XTX's are faster top end. My sled basically tops out at 89. Does anyone know what the top speed of a XTX?
Studroes144
- Oct 30, 2013
Xtx uses taller gearing than the ltx, but the xtx also has smaller drivers. Theoretical top speeds of the ltx and xtx are within 1 mph of each other. At 89 mph im assuming yours is just a stock sled?
yzf1999
- Dec 25, 2006
Yeah it's totally stock
yzf1999
- Dec 25, 2006
Would my LTX be a dog with XTX gearing?
Studroes144
- Oct 30, 2013
As far as I know there isn't really anyone that's done it on a stocker, personally I don't think it will have any negative affect at all. Stock vipers are still very torquey and I don't see them having any trouble pulling taller gearing
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
94 mph on my xtx le with a 2.25 track and just a bit of flipper left. Stock gears. Prefect gearing for a crossover sled I think.
