SPEEDMAX
need help ,apex2871 turbo whit lauch master engagment is at 5500 rpm only built 1psi off boost on stutter air fuel ratio is 11.2 at that rpm timming is +4 at 5500 rpm i have a rb3 rapid bike need more boost for take off
FLYBYU
your engine could be to warm. you need to find the right temp.
TURBO TIME
too rich try leaning out that rpm range, my 2871 is building 7psi at 5000 on the stutter, you will know when you find the sweet spot it sounds like a jet spooling up!!!
- 44K
