MTX Limiter Strap Settings?
Bodacious
Leelanau County, Mi.
So are most of you running the limiters at full length posistioning or snuging them up? Mine came set at Max length from the dealer. I'm getting a lot of inside ski lift on hardpack. Also front end seems very twitchy ie: likes to hook and dive on hardpack conditions with stock skis.
I have mine all the way loose. I have the rear as stiff as can be (torsion springs & transfer rods) and even with the limiters out transfer is about right. My skis are usually just couple inches above the snow while climbing.
