MTX SE A-Arms on XTX
gc_srt
Saskatchewan
I was thinking about changing my stock A-Arms to MTX SE A-Arms for $200 but curious what everone's thoughts are? Looks like it would change the ski stance from 41.3 to 40.7 inches comparing the two sleds. Not sure if I have to change the entire front end out or just the A-arms. I assume I would have to do the tie rods as well.
Has anyone does this yet? FYI, the skinz front end kit is not in the cards this year. Also, I already removed the sway bar so that is not an issue.
If you want to carve better in the deep snow then go for it. If you want to maintain stability well, it won't be as stable since the stance is narrower. You would need to change the tie rods as well. I had wide a-arms on my RXM and went back to the narrow stance. I had to change the shocks on that one though.
I think the mtx se and the xtx has the same a-arms
Apparently it is with the exspection of sway bar mount. The MTX SE does not have a sway bar. FYI, I didn't end up purchasing the A-arms.
