MTX Track Change
sledsrfun
Woodland, WA
My new Powerclaw track arrived yesterday. Started doing the install today. Little more difficult than I anticipated. Turned out to be a good thing. The bearing on the clutch side of the drive shaft was really rough. Have to change it out. Anybody else had that problem? Only 1400 miles on the sled. Short life for a bearing.
I don't have much experience with different tracks. Should I be concerned that the powerclaw is clipped every other and not fully clipped like the Maverick.
Lower bolt holding the bottom sprocket on was fine. Not broken.
Clipped every other isn't an issue. I'll find out about my bearing in a month or so when I swap to the Powerclaw. Only 500 miles on mine though.
