Track Vibration - Powerclaw 153
One other thing that might be causing the vibration is the track is only half clipped and the clips are alternating side to side. So when each driver tooth engages the track, the left side is clipped and the right side isn't, and visa versa on the next tooth.
With our drivers being 7 tooth and the cat being 8, I wonder if this is combo of clips and smaller drivers are contributing to the vibration.
Having ridden it a few times now, it seems to be the worst when you first start your ride and gets better the more you miles you put onit, but starting out on any day, it vibrates, regardless of whether you are on powder or a trail.
OTM
