Mtx viper 153 mpi trail turbo clutching
rla1
saskatchewan
Canada
2017 sidewinder btx le,2021 mountain max le,2011 apex xtx,2012 arctic cat xf m8
This is what the dealer sent me,(Yamaha part#s)90501-583l0-00 primary spring,90508-60016-00 secondary spring,8bv-17604-71-00(47 deg )helix and 6x90266-06002-00 (13.3/hole) for the stock 8bu 10 weights.Is this set up going to be ok for 1600-1800 ft or do I need to make some changes before even installing,have been told already that I will be on the rev limiter if I do not add more weight ,any suggestions/advice would be appreciated, thanks.
