my 06 apex rtx clutching test
tofast
NH
Hi I have heal clickers roller seconded primary has swing arms I have wait in heel and bolt 2 washers . In second I have 42 strait helics black spring I am having a hard time with it it goes 1080 to 1120 top need suggestions I am sick playing with it staring to think I should go stock arms please help
What did you just say? The stock yamaha secondary works well with the heelclickers. Which heelclickers do you have in the primary? If you are refering the the extruded arm on the weight as being a swing arm I could assume you have the old 2 speeds. With what Spring?You should have the white primary spring? May I assume you have a HCX roller secondary with a 42 degree helix, but with what spring?Should be yellow? You state you have a black spring is it in your primary? Pictures might help if you are having trouble explaining?lol
or leave all well enough alone and just put 2 grams in the tip,( end of weight, furthest from swing arm) and see what happens.
