My Apex / MPI Supercharges Is A Blast To Ride.............
SJC
Bravo to Yamaha for building the Apex Mountain that does many things very well in and around the terrain of western wyoming. And Bravo to the crew at MPI for complimenting the Apex with an awesome supercharger that flat ot rips. The MPI controler as well is very user friendly and dials in the Apex in 20 seconds or less for any mountain riding condition, elevation or temp change....... I rate the package an A+. (and no under the hood heat like my front mount turbo :D) The Apex is just a blast to ride and the folks at TJ Sport's have put together an awesome mountain setup that has put grins on my face as well as a few others.
Im also very impressed with the Mavrick track which is a home run and hooks up very well with the SC in the backcountry. Those 2.5 paddles weren't designed for trails that for sure. The Apex cuts the rug with the best of them and than some. It side hills very well on both sides of the sled, which imo is a tribute to yamahas well designed and well balanced sleds.
Im just loving this sled more and more with every mile.
Happy Holiday's
steve
PL seats & exhaust
Hey OT,
Are you running 7 psi or 10 ? Just curious ? How do you think the 7 psi will be as compared to the 10 ? Any setup issues ? Are you running 50/50 ? Glad to hear it is running well. Finally the wait is over !
vectorboy, the MPI SC is set for 10# however everytime i squeeze a handful of the flipper im going so fast i can't see the boost gauge to clear to verify.:D Im also currently running 50/50 but will be doing the compression mod in a few days.
As for the setup the crew at TJ Sports have an awesome setup that works very well with user friendly MPI controler. The only way you won't be happy is if your running a poor setup, the MPI SC in the Apex makes awesome power
steve
If i had to guess somewhere between 558 and 568. Now that i have some time on the sled and like the setup i'll get the sled weighed......Holz A arms save another 7# :D :D :D im just not sure i really need them :D
steve
