mopar nut
hey i was just wondering what this could be. i have a 2004 Yamaha warrior with 1200 km's on it and the clutch makes a rattle noise when it is at idle.
do u guys know what this could be?????
THANKS
THANKS
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
Definitely the norm with all RX1's there are some changes you can make to eliminate some of it but every one i've seen does it at idle. I would'nt be concerned one bit 8500 on my 03 and it has always done it.
mopar nut
well thats good lol.i was concerned that it was going to fly off on the trail lol. (just like my old ski doo 600 sdi)
RX1-er-2005
Just bring up your IDLE to 1700-1900rpm and the noise will vanish, you might want to check if your CARBS are in SYNC, it also makes a BIG difference...
mikeRX
My 03 RX-1 makes the same noise. Dealer said it was normal for that model.
RedRocket
Between the clutch and the gear reduction system, it's normal noise. I also raised my idle to 1800 and the noise is barely noticeable. Also, raising the idle made starting a lot easier. It was at 1200 from the factory and I always had to give it just a little gas while cranking, now I just turn the key.
I know the clutch isn't worn, the sled only has 750 original miles on it. Man I hope it snows this year.
rx1ryda989
- Feb 7, 2007
my 03 did it until i put the heel clickers and different rollers in. But like the other guys said, turning up the idle helps.
