my M-10
ger
Ontario
not that all of you have not seen a m 10 but here is mine.
By the way thanks to everyone that offered help and opinions
Ger :Rockon:
Ger,looks nice.wasnt so bad to install ,was it? so hows it ride?are you as happy with yours as i am with mine? let me know.
Yes it was easy other than the confusion on the front shaft and the grinding.After I talked to Mr sledand called fast I found out that they changed the mount. The guy at fast said I could just take the shaft and machine off .1" off 1/4" back and then notch out the collar. That is what I did and it went in as per TY's instructions.
I only have about 10 miles on a lake so it is still stiff but I hit some big stuff on a small sidetrail and wow what a difference.
Yes I am verry happy so far , but I need snow now. I am looking into the big wheel kit for the back now :drink: . I just cant stop doing stuff.
Have you rode yours much ?
Looks great. You can go find the roughest stuff you can and beat it to break it in. Also, if you want to change the spring color, Lowes sells PLASTICDIP in spray form in several colors, I did mine in black and it has held up great. The blue looks like Yammie blue.
thanks for the tip indy .
I might just do that .
I am going to get a M 10 sticker for the tunnel from the Polaris dealer I think
