TT
I haven`t been able to ride alot this winter - due to wrenching on my sled.
But I finally got her toghether - what a blast with boost
If something is spelled wrong is due to looooooooooong arms after riding today - LOL!
I bought a used kit. That`s been upgraded with (new hoses, bypass vavle, billet carb caps, billet T`s, mcx carb rings, AN fittings in intercooler plenum chamber, wideband, liquid filled boost guage etc.)
I runs like a champ thanks to all of you members (spray25, skydog, woodsrider, Jonny Rocket, rxrider, ted j. etc..) that has posted in the turbo- and RXM section. Your posts has been such a great help under the the install
If something is spelled wrong is due to looooooooooong arms after riding today - LOL!I bought a used kit. That`s been upgraded with (new hoses, bypass vavle, billet carb caps, billet T`s, mcx carb rings, AN fittings in intercooler plenum chamber, wideband, liquid filled boost guage etc.)
MT RX1 Mountain Man
Sweet looking sled!
TT
Thanks!
TT
Here are links to other mods. I have done to the sled over the years:
Rear heat exchanger mod with MPI tunnel extension:
http://www.ty4stroke.com/viewtopic.php?p=293157&highlight=#293157
Install of the apex mountain skid:
http://www.ty4stroke.com/viewtopic.php?p=339528#339528
obr
- Aug 16, 2005
- Alta, Norway
- www.techservices.no
Great sled you've finally got together TT
TT
Thanks!
look's like a blast to ride.
TT
It puts a big smile on my face every time!
TT
Added some pics of the AN-fittings welded to the plemun chamber of the aribox/intercooler.
It is a tight fit if you have the stock battery and battery tray. You have to remove the plastic cover that goes over the battery to make it fit. I also added some foam/polstery (not sure if it's the right word) to the battery tray. This was done to prevent any rubbing on the battery.
TT
Here is some updates for the summer:
- cr-racing speedometer bracket
- boost and wideband bracket
- tunnel supports (apex mountain tunnel)
- aluminium plate where the speedometer used to go.
Tunnel supports and aluminium plate are self made and cut out on a water jet. If someone need the CAD file after installing a wildchild kit - let me know and I will mail it to you.
obr
- Aug 16, 2005
- Alta, Norway
That lookd GREAT..would you build more of those speedometer ones and sell one to me???
Thanks, Bull
Thanks, Bull
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Cool tuning fork plate to cover up the speedo hole, need one as well
TT
obr and rxrider:
Send me a pm with your email, and I will mail you the CAD-file for the plate and the email address to the company I used.
I have used Grenland mekaniske AS two times to cut ot parts - excellent service.
TT
Obr:
I have e-mailed you the AutoCad file
obr
- Aug 16, 2005
- Alta, Norway
got it, thanks. I'll look into the oil lines as soon as i start mounting the kit...might be a while, so be patient..LOL
