was checking my wheels during pre season on 2016 apex xtx and found #21 loose on the shaft and both wheel mounts loose. i know they where tight during last year preseason. what i found was that they started moving on #19 shaft and as the shaft is aluminum, they ate the shaft and the spacer wore down so it was rattling around on the shaft. shaft is toast from this coming loose. i did discover that you can use the same position shaft from a 2011-15 apex xtx and the wheel mounts fit as well. you need to use the bolts from the 2011-15 to mount the shaft as they are longer than the factory ones on the 2016-18 xtx suspension. to get the sleeve tight again, i filed the ends down square and found a 13/16" id washer that i honed out with a dremmel to use as a spacer. got it all together with used 11 parts other than the spacer sleeve.
shaft 24 is the one i used.
now i need to get exup cables as the both just broke on me when trying to cycle valve to adjust it.
I think that too. Love /hate relationship. Keeps things exciting!
Common on these.
Maim, I've used the cross shaft from the 1997-2004 rear suspensions along with the wheels that have the 6205 bearing.
#41 pictured.
#41 pictured.
1998 Yamaha SRX600 (SRX600B) Track Suspension 2 | CyclePartsNation
Shop online for OEM Track Suspension 2 parts that fit your 1998 Yamaha SRX600 (SRX600B), search all our OEM Parts or call at 269-385-1540
www.cyclepartsnation.com
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Some of my cobb jobs like reinforcing egged out vector rail holes when the front shock came loose work fine!! Whatever works! Its ok to reinvent the wheel on these!!lolView attachment 1750152016 apex xtx
View attachment 1750162011 apex xtx
Used a steel plate bolted to the rail and drilled new holes....10 years ago!
Also, a friend has 2 apexs with exup, cables broke,so he just fixed them open and he cant tell any difference in performance on either one!
i need to do one of these on betsy as the torsion springs mount on the bolts that hold on the rear shock lower mount. already replaced one rail because of this. right now it is patched together with the special washers that are discontinued from the phazer II front w arm mount to the rail and lock tight as i needed to get the 16 in for its annual service.Some of my cobb jobs like reinforcing egged out vector rail holes when the front shock came loose work fine!! Whatever works! Its ok to reinvent the wheel on these!!lol
got cables on order but not coming in until on ty ride. going to make a plate out of body metal to mount to one of the bolts for the sheild to bolt it open for this ride.
i keep the rear axle in stock for the apex xtx sleds as it is used in everything i own but the vk 540 sleds.
