Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Yamaha apparently has two versions of the high performance graphite slides (narrow & wide) for my '07 Apex GT (121")
SMA-8CM92-70-HP (about 1 1/4" wide).
SMA-8FU92-00-HP (about 1 3/8" wide).
Anybody care to comment on the merits of either?
I need to make a decision and any help would be apreciated!
hemiram
i use the narrow slides on my 06 attak not the graphite but the standard ones
SharkAttak
the narrower ones are easier to put thru the track windows, there cheaper and less drag, which will give you more speed
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
I got the graphites off of hiperf.com They are cheaper than yamaha and last great. In Muni when everyone else burnt through 2 sets, I had 3/4 of mine left. Maxdlx
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
definitely NARROW last longer IMO,and easier to install...and i believe faster on radar.
Dan
Dan
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Thanks guys!
As always, I apreciate all of your input.
I am curious why Yamaha makes two versions of this slide that are so close (about 1/8") in width?
Are there any other differences between SMA-8CM92-70-HP & SMA-8FU92-00-HP besides the width?
I am assuming that the wider one is what Yamaha calls out for my Apex, so the thinner one must be for another application? A sled with narrower track windows?
I will probably go with the thinner ones based on all of your recomendations. My dealer has both types and they are the same price ($16.95 ea less my 15% disc.).
My dealer however thought that the wider ones will last longer since there is more surface area. However I suppose that you could look at that the opposite way as the wider ones may create more friction?
As usual I'm probably overanalyzing this, but I like to try to understand everything best as possible, plus I do enjoy the discussion.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
thinner ones allow more window area and allows more snow in to cool slider,and they last LONGER.....faster on top end too.
Dan
Dan
- 6K
