InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Hey, so I picked up a used Hurricane 190 Kit for my 14 Viper. Having a turbo already on the 16 and no Winders available, figured this was the best way to go.
Got the kit, came with intercooler, gauges, PC-V and pressure regulator.
Pressure regulator? Hrmmm something is not adding up here I thought as nowhere on Hurricane site does it say the 190 kit comes with a pressure regulator. Turns out the mountain sled it came out of had a head shim in it and this was actually a 240 kit. That's okay, even better. We removed the regulator and put back the OEM dampener, installed the intercooler and turbo, plumbed it up and all seems good.
What I am looking for if anyone has one is PC-V map for that set up. I have contacted Dave and he is understandably very busy so I thought I would reach out to my fellow TYers.
Have you looked in the Maps area?
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
I had a used Hurricane 190 kit a couple of years ago. I believe I have the map that came with it. It didn't work well for my '18 because I believe the PCV map was created when the kit was first sold in '14 and didn't compensate for future ECU changes but it was a good starting baseline. I ended up using Autotune to create a better map suited for the '18.
PM me your email address if you are interested.
Can you post that map for others?
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
Posted in Viper Maps Download
Awesome!! ThanksPosted in Viper Maps Download
EricPoint
- Dec 12, 2023
- Sr viper ltx 2014 mpi turbo
Care to share it with me?I had a used Hurricane 190 kit a couple of years ago. I believe I have the map that came with it. It didn't work well for my '18 because I believe the PCV map was created when the kit was first sold in '14 and didn't compensate for future ECU changes but it was a good starting baseline. I ended up using Autotune to create a better map suited for the '18.
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
It's posted here:Care to share it with me?
Home >Forums > 4 Stroke Performance > RB3, PCIII, other EFI Maps > Viper Maps Download
