Tork
for Bluedog.
The standard windshield for the ER is the Mid 14.25 inch,
is that correct?
Oh the tall 16" is that tall enough?
17.75 inch extra tall, anybody tried that one? Is it too tall
Thanks much
is that correct?
Thanks much
Tork
ttt
Arctic Express
I think the ER is only @12.5" And the Mid size is 14.5". I replaced mine with a mid size and gained about 1 3/4 to 2". Measure from top of Speedo to top of windshield. I have"t had a change to ride it with the mid-size yet...no snow. Looks like it should work ok heightwise. Debated on the High sheild at first.... may have to go higher yet.
Pullinfront
Artic Express is correct the standard shield on the ER and Attak is the low shield.
Pullinfront
Pullinfront
Starry Knight
I just put the Yami "Mid" shield (silver with a clear center) on my GT. It's a lot higher than the stock one. I'd say it's the same height as you would normally see on a touring or two up.
Only problem with it is the screw holes don't line up perfectly, and it's bowed out between the first and second screws on the right hand side. Anybody else have that when they swapped out their windshield?
Ground Blizzard
AE, thanks for posting how to measure the shield!! I had my sled fixed and the shield was one of the items replaced. I knew I went with a taller shield and the one they put on was the "taller ver." but it still seemed shorter than I had. I now know I had the extra tall.
