Yamahnator
Ok, so I put some riser on. 2 inch sportech risers on the Phazer. Get everything set and fire it up. I immediately see the check engine light flashing when I turn the key, also the odometer and the rpms flash back and forth. Fire it up, gets started and idles ok.
Try the flipper and it stutters and stutters and then all of a sudden goes (putting a small dent in my garage door bottom panel which was only 2 inch away, thankfully I was wondering if it might do that and had hit the kill switch as soon as it moved).
This is the TORS I'm assuming. How do I fix this? Seems to be plenty of room for the throttle cable, but I must have hit something or pulled it out of whack? Supposed to go riding tomorro!
Len Todd
Get your manual out and check/adjust TORS. You need to have the right throttle cable free-play. Also, check the electrical connections in the areas you disturbed. Do you need to reroute the cables to have adequate length when turning?
