TORS when standing ?
acpantera
W.N.Y.
22 TCAT+ATAC+EPS
Has anyone had a problem with tors in different riding positions. I had put a two inch riser on my venture and I notice that tors seems to activate while I am standing or kneeling, I checked the cable adjustment and I may have it on the loose side. This has been rather embarassing because two friends off mine tried the sled and tors hit for both of them. Has anyone activated tors by giving some down pressure on the throttle while depessing it........other than being very careful of this how might I stop this from happening again. It almost got me stuck and stopped me on a rather steep hill !!!! Not liking this part at all. Other than that its been a dream come true.
You could try adjusting your throttle cable and idle to spec. ;)!
tors
If it only happens when your standing or kneeling, I'd have to think it's in the way you grip the throttle and the bar in these positions?? If it was an adjustment issue, it seems like it would do it regardless of rider position.
Freeplay at the lever should measure 2.0-3.0 mm (.08-.12 inch)
