WINDER1987
Hi guys I'm trying to install my copper donuts and new header but how do u pull the old header our it appears there isn't enough room to move it forward to get by the bracket to pull it out the rear this is on a nytro
Pstn head
I beilieve to get it out easily you need to remove the flex pipes, some have forced it out but not pretty. When I removed mine I drilled out the rivets holding the header braket, but be sure replace rivets with quality ones. Also there are 2 alen bolts holding the header to the bracket, losses those off a little no need to remove completely.
Hope that helps
Hope that helps
WINDER1987
Ok thanks I ended up removing the flex pipes and got the new one on is there a easy way to check for any exhaust leaks before putting everything back together?
WINDER1987
I hooked the tank up and started it got a lot of smoke inside the manifold Area is this normal with a new header and copper donuts or do I have a leak somewhere it doesn't seem to smoke until. It's been idling for about a minute
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I recently installed copper donuts and had quite a bit of smoke too. I let it run a few times and the smoke has subsided. Maybe it is the copper donuts... or the penetrating oil I used when dismantling it in the first place.
WINDER1987
ya thats what I'm thinking i would imagine you should here it if you have a exhaust leak more than anything
06_apex
- Jan 10, 2015
- PEI
- 2022 sidewinder ltx le
do a wet rag test or a tennis ball. start the sled and plug your exhaust if it quits you have no leaks. If it spits and sputters you have a leak.
kurzy
- Mar 25, 2011
- Peterborough On, Can.
- '08 40th. Anniversary Nytro RTX
RDAY, I went through the same thing in January. I changed mine and had a scary smoke show. Button it up and ride it, the smoke will stop. I didn't take the flex pipes off. I drilled the rivets and removed the mounting bracket. Good luck.
WINDER1987
Ok i got everything back together and I noticed that there is a small leak where the silencer connects to the header pipe is this a big deal or no?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Fix the leak. It could lead to buying another header.
WINDER1987
What would cause it though the gasket from the header to the silencer looked in great shape? And does anyone have a tip for reinstalling the shroud over the exhaust easier what a pita lol
