Just wondering what I am missing I cant here my relays cycle and my fuel pump does not have power I checked the fuses on the Right side but they are all good is there any other fuses or relays that could do this?
schmeg
The fuel pump relay itself is not working. It's the second one out from the bulkhead. If the sled is out where it is cold, warm up the relay by taking it out and bring it inside, or put a hair drier to it.
johnketch
johnketch
first check the relay way easier and there is a known problem with moisture in the relay freezing i cary a spare and they are only 7 or 8 bucks
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
It's the ground wires above your primary clutch. Does the starter turn the engine over?
Yes the sled turns over gauges come on but you can not here the fuel pump or the relays cycle or click just not getting power.
ApexDriller
dittoschmeg said:The fuel pump relay itself is not working. It's the second one out from the bulkhead. If the sled is out where it is cold, warm up the relay by taking it out and bring it inside, or put a hair drier to it.
Greasemonkey
- Dec 1, 2006
- Somewhere in the Pinelands of NJ
99% sure this is the problem. It's defiantly a known issue.ApexDriller said:dittoschmeg said:The fuel pump relay itself is not working. It's the second one out from the bulkhead. If the sled is out where it is cold, warm up the relay by taking it out and bring it inside, or put a hair drier to it.
