MarkRTX
Sled has spit and sputtered since I got it back from the dealership. Only did some lake runs a week or so ago when problems started. After 5-6 runs it would spit and loose power and almost stall. thought it may have been my new PC3 and ing module so went back to stock except for ram air lid which I adjusted on the pod low fuel settings started at 12 ran 10 no problems at all lat year, then ten then 7 thought it may have been bad fuel so ran it this weekend and put 3 tanks thru it with seafoam and still real hesitant almost stalls after completely letting off the throttle then runs fine also new gremlin was the fuel pump relay froze up took them all out and warmed them up no problem Any ideas? Plugs maybe running cr10 plugs but have never had a problem in the past Need help wanna ride this weekend finally some good snow here in maine Thanks mark
Did you ever find the resolution to this problem?
