leaddog
Just had my shock revalved. Now the sled does not see the shock, as if the wire was broken. I have 12 volts from the sled to the shock with the key on and 5 ohms across the shock wires. Can anyone help me?
the solenoid is very easy to remove, but i bet the wire is chafed through. they all need heavier insulation.leaddog said:Just had my shock revalved. Now the sled does not see the shock, as if the wire was broken. I have 12 volts from the sled to the shock with the key on and 5 ohms across the shock wires. Can anyone help me?![]()
