Newyamahaowner
- Apr 30, 2014
- Ontario Canada
- 2015 viper xtx se
2004 Mxz 600 Sdi sold
1999 formula z 670 sold
i am installing a hid light kit and can't get the ring that holds the headlight in back on anyone have any idea or tip to get them on
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
They are tricky if your talking about the spring clip ring that pushes in the bulb and holds it in. You have to get both side pushed down then rotate the ring as your pushing the tabs down. You just about need 3 hands to do it. Keep playing with it , you will get it.
I used long needle nose. Little tricky.
2014 viper, mpi
2009 Phazer 144"
2014 viper, mpi
2009 Phazer 144"
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
After a couple of hours of trying to be a contortionist to get both hands in at the same time and a lot colourful words, I ended up making a tool that holds the retainer, and you can push on it and turn in the retainer with one hand.
I can't seem to upload a picture of the tool to help you out with making one.
The tool is a piece of 1 in PVC electrical conduit (swaged end about an inch and a half long).
Cut grooves just wide enough to hold the ears on the retainer and deep enough to allow you to compress the retainer and twist it into place
nherbst454
- Feb 25, 2014
- Woodbury, MN
- 2014 SR Viper XTX-SE
Did you remove the headlight assembly or do it in the sled?
It seemed to go pretty easily for me but I did have the headlight on my workbench.
Nytros rule
- Jan 30, 2011
- Rider Nation
On the sled
