Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Can you post up the part numbers you needed to complete the swap?The Sidewinder Headlight is lighter then the viper's
Dealerjohn
- Mar 26, 2010
- Labrador
- 2015 MTX Viper, XTX Viper, 2001 SRX 700
If anyone has a chance to get a weight on the sidewinder light please let me know.
- Apr 14, 2003
- Hessel, Michigan
Crap, I could have weighed mine when it was apart....
Dealerjohn
- Mar 26, 2010
- Labrador
No worries my friend, hopefully someone will chime in eventually!Crap, I could have weighed mine when it was apart....
SR Viper
- Mar 15, 2013
- 2014 Sr Viper XTX, 2007 Apex RTX, 2006 Nytro ER, 1989 Phazer, 1985 Sno scoot, 1980 ET 250
SR Viper
- Mar 15, 2013
Thats all the pictures of the mod like I promised lol.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Any parts required for the mod?Thats all the pictures of the mod like I promised lol.
SR Viper
- Mar 15, 2013
Just the new headlight and the wiring harness, anything else you will have to fabricate yourself .
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
You mentioned you needed to make some adjustments to the headlight mounts in order to fit this in place. Would that be the black shroud that also holds the windshield and gauge pod or am I looking at the wrong thing? I've been looking into getting the headlight and the part above (no clue what it's called) from a Sidewinder BTX SE because of the venting (more for looks but I would imagine any bit helps). Thoughts?
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
Very risky but Acetone will make anything stick to the lens. If you get it anywhere else on lens it will be ruined though for sure. Could also just drill small holes in reflector and stick LED strip behind it.
Just FYI but as a last-ditch-effort I took acetone on a rag to my old Phazer's headlight trying to remove the adhesive residue from Seth's headlight blackout from his racing days after nothing else at all would even touch it. It took the adhesive off with ease and the headlight lens was fine. Not saying if someone else tries it it would turn out the same, but just wanted to throw that out there
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have a used headlight and harness if anyone is interested in doing this mod.
- 13K
