RX1red
I have been spitting middle boogie wheels on my RX1 2005 since I bought it.I bought new wheels that the dealer told me were updated and would last 5000 miles.Still have the same problem.Is there anyone out there with a solution???
SLEDSTART
Run the polaris 5.35 wheel. I bought the Kimpex wheels in blue. They are a smidge larger in diameter and greatly help on hyfax wear. I have 4100 miles on those wheels. If I remember...you have to also use a longer bolt. Someone here helped me out so I am sure if you search "polaris wheels" or "hyfax wear" you will find the bolt number you will need from Yamaha. I know someone on here knows.
I replace bearings in them every season and good to go. Plus they are cheaper than Yamaha wheels. You wont regret it.
Make sure your track is not too tight and aligned proper as well.
