bradb
stuck at trail shelter, sled wont start shows code 43
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Code 43 Fuel system voltage - Power supply to the fuel injectors and fuel pump is not normal.
Battery dead?
Battery dead?
Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
43 is is the fuel system voltage monitor... meaning the power to the injectors and fuel pump is not right. Try pulling your black off the battery for a minute. Put it back on and start it and don't go to far and see if it comes back. check the plugs leading to the injectors. May have a rub... try cycling the power first then try the others.
bradb
no battery is good.Grimm said:Code 43 Fuel system voltage - Power supply to the fuel injectors and fuel pump is not normal. Battery dead?
Rayman5271
- Oct 3, 2009
- Northern Maine
What year is the sled?
bradb
code 43 is still on, tried what you saidbradb said:no battery is good.Grimm said:Code 43 Fuel system voltage - Power supply to the fuel injectors and fuel pump is not normal. Battery dead?
bradb
09 nytro xtx
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
It could be a problem with the fuel injection system relay. It's located in the front nose area of the sled. I think there's a couple or few relays there. Is that area of the sled wet? frozen? Take it out and air dry. I don't know if it would be interchangeable with any other relays on the sled. Could be worth it to swap them around to get you home.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
There is also a fuel injection system fuse 10amps just forward of the oil tank....check and replace if burnt.
bradb
is there a fuse for this and if so where
Rayman5271
- Oct 3, 2009
- Northern Maine
Sorry for the slow replies... snow is making the satellite loose internet. Like Grim said... check that relay... somehow there is continuity there. Pull the system relay coupler and ecu coupler and just blow them out and check the pins and make sure they're not loose. Don't suppose you have access to a meter?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Just in front of the oil tank, there are three fuses, the first is to house a spare, the second is the fuel injector fuse and the third square one is the main fuse. The middle fuse is the fuel injector one...should be 10 amps.
The first fuse is a spare and probably a 10 amp, however there should be spares in the fuse box above the brake rotor.
bradb
everythng is so stiff very cold here cant seem to get them loose no room to pry the keepers out of the way
Rayman5271
- Oct 3, 2009
- Northern Maine
Was it the fuse... ?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I'm pretty much out of ideas...do you have a way home? Anybody with you?
