2013 nytro won’t start
jaypluggin
Michigan
Yamaha nytro
My nytro won’t start after riding the last 3 days. Battery seems strong; I have the check engine symbol flashing on the speedo read out and it flashes from the trip odometer to the speed reading “43”. Not stuck on the trail but stuck on the trail. Any quick fixes? All fuses look good. thanks.
I think 43 is fuel system voltage. I'd pull and warm the fuel pump relay(is it cycling) and check your grounds.
Fuel pump relay!! Pour some warm water on it! Will fire right up. In the nose of the sled
The fuel system gets power from the fuse at the starter relay.
Check it and also the connector itself. Unplug it and look closely at the female terminals.
Thanks for the reply’s. Got to the trail head and she started right up. It was over heating when I turned it off the other night should of road it up and down the trail before loading it up.
Maybe you should have added the over heating problem on your first post. Pretty hard to figure out your problems when you leave half the problem out.
Overheating has nothing to do with code 43. Problem is intermittent and most likely will return. Still need to check what I first posted.
Probably not but still would have been nice to get the whole story
