TBNSR
I have been reading a lot of posts that people are seeing 120+ on their Attaks. I couldn't get more than 112 out of the dream meter this weekend. Any thoughts to why mine seems much slower than others are reporting? Everything is stock.
Turk
Tech Advisor
120 on the speedo is easy if your running perfectly flat very hard pack snow with no headwind . Any loose snow on the surface or a headwind will knock you down huge.
TBNSR
Turk said:120 on the speedo is easy if your running perfectly flat very hard pack snow with no headwind . Any loose snow on the surface or a headwind will knock you down huge.
I was on hard pack on Lake Gogebic in Michigan. I went both ways and did get 4 more out of it one way compared to the other. I was just expecting much more than 112. It still is fast though.
radta7
- Dec 8, 2005
- Northern IL
- 2020 Sidewinder LT-X GT
TBNSR I did 124 on the same lake from the hoop to the lodge and the lodge to the trail entrance by the state park. How many miles does your sled have? Was it still compact or did you have fresh snow? Lots of factors play into it. My mph was Dreamometer time as well.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Somethings up, I saw 122 on the dream meter on my Rage today down a hardpack road with a 1.5 paddle track before I had to back off. What shape is your drive belt in?
Mikecam
Hey TBNSR read this thread. Notice you have the triple points.
http://www.ty4stroke.com/viewtopic.php?t=39434
I was on gogebic this week, 113 was all I could get out of my stock 07 attak,500 miles, and Simmons skis! I suspect the 4 runners don't help! Jay
power valve
- Dec 10, 2006
don't worry most of the time that is all i see is 112mph on my dream meter and i'm in front of an apex, two attacks and f1000. i can hold off the new mach z's for 2000ft. put it on a road and you will see 123mph.
Blown Up
There are a ton of factors that come into play in getting top speed. Keep in mind that a lot of the really high speeds you see posted are on plowed ice tracks. If you are running on snow, it makes a big difference.
I saw 118 on my attak gt speedo this weekend out on the lake and was pulling away quickly from all the 800's that were running.
MXD
The most I have ever seen on my 06 ER was 111 on a choppy packed lake.
Beast from the East
I saw 119 on the dreameter and 105 gps
Wanted to get a baseline so I can start the clutching.
Hope to see 115 gps if at all possible. Time to start spending!
Russ
Russ
Blown Up
I have mine clutched for hard acceleration, not top speed, so I was quite happy to see 118 on the speedo. I do mostly trail riding, so I am not too worried about going 120mph.
I am coming off a good running 05 mach Z and have approx. 450 miles on my attak gt now and this is the best sled I have ever owned!
welterracer
rode 1080 miles in the U.P.
Highest speed i saw was 111 on the dreammeter Which ive been told is good on snow...
it takes perfect conditons or ice to go faster
