Need Secondary/jackshaft help
powderstash
Carbondale, CO
Website
www.downvalleytrash.com
I searched and searched and could not find the answer, so here's my question.
2 rides ago I started noticing a ticking noise under my hood and being an idiot I ignored it. Anyway, turns out my secondary is wobbling at lower RPM's and then the wobble goes away. Is this a jackshaft bearing issue? I replaced mine 500 miles ago (and 4 years ago but that's another story). Any insight would be appreciated
Did you put the new style jackshaft bearing on when you replaced the jackshaft bearing 4 years ago?
If so, there is a large nut (more like a ring) that is tightened to hold the bearing in place. Perhaps yours isn't as tight as it needs to be? I remember it being tough to get to (I did mine about 4 years ago too).
Good Luck
Frosty
Thanks Frosty. Yeah, I put the new style in when I rebuilt the whole sled after totaling it on a rock. I'll tear into it and see if that is the issue.
