dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
I have C&A razors and 6"shaper bars. and it is a pain to turn my snowmobile. I got on my buddies 2011 skidoo etec and it turned so easy. Will a nytro ever turn as easy as a skidoo? Looking to get different skis or is there something i can do to help reduce the hard steering?
Anyone who has went from C&A razors to curves please let me know if they are worth it!
yamaguy426
Loosen your limiter straps to take the weight off the front end and your sled will turn easier. Just don't loosen to much or your ski's will be off the ground so much it won't matter what brand they are!
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
Whats holes do you recommend for limiter straps?
mcamzr
I have C&A Razors with 9in shaper bars. I just tonight messed around a bit to help with the heavy front end feel on decell. I am all the way loose on the front straps and just went the second hole from loose on the rear strap. Rear springs on medium center shock with about 1/2 inch threads showing and 57 lbs in the fox clots up front. It was way lighter. Not doo xp light but I could one hand a turn around in the field with my 2 boys riding 3up with me. I will say that the slightest change is noticeable.
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
Split Rail skis hands down the best. no darting, railsaround the corners and a lot less effort.
09NytroRTX
I agree Split Rail Skis reduce the effort by a lot!!
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
What do you prefer besides split rail on a limited budget.
09NytroRTX
I have only ran the split rails as far as after market but I when I was looking and may still make a change next year to try out the Curve ski's.
shockwave
- Feb 25, 2010
- St Paul d'abbotsford Québec
- 09 Phazer RTX
I have the same probleme as you, I will be going with Curves XS.
Look at this, it may help you.
http://www.ty4stroke.com/viewtopic.php? ... ht=lighter
Good luck
Good luck
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Does anyone have any experience with the 6" Slydog trail ski?
