4x4 said:There is no DC power source on the non electric start Enticer, AC only. There is a 12volt regulator and if it were unplugged the lights burn out. The HI/LO switches run the circuit through a resistor when on low. Adding a on/off switch into the circuit is easy, and can be on hot or ground wire depending on which is easier.
