radianguy
- Jan 1, 2007
I have been doing a lot of reading on clutching but can't find what I'm looking for.
My 09 XTX has all stock clutching, with a 1.75" back country track and 20/39 gearing. I am revving out to 9150 +- 20-30 rpm depending on conditions. I want to lower my top rpm by 200 rpm or so to get me back down around 8900-9000 rpm. I do not want to change weights, I would like to do this by changing the primary spring. My question is which spring would I change to?
I have also thought about doing the 14.5mm rollers to lower engagement, and give better mid range pull, would this drop my top rpm? Or would a simple spring change give me what I am looking for?
piped bravo
If you have the b-s-b (35/101) ....the b-p-b (30/96) ....would drop your RPM close to what you are looking for and a lower engagement.
But if your are seeing those rpms on hard pack....it might seem low with a load on the motor in snow.
I would not worry to much about close to 9000 rpm....this motor loves to grunt and as long as you are seeing 8400 to 9000 ....it will be fine.
radianguy
- Jan 1, 2007
The thing is I think I am past the power curve. On a long straight away, when I pin it my speed is slow to climb after 120-130 km/h. I know the 1.75 isn't helping me but I think revving past 9100 is hurting me. Low end is great, but mid range isn't there like it used to be, and I would like to have it back. I don't care if it won't break 100 mph but I want to get there like it used to.
TJSHORES
Go with the Y-P-Y spring and 14.5mm rollers with stock weights and the Back Country track. B-P-B spring will shift out to slowly. This is a great setup for a stock motor with that track. Engagement should be around 3300rpm and top end with a deep snow load should be around 8500-8600rpm. There is a hugh seat of the pants diff from low through mid band pull. Just keep in mind that you'll lose most of the engine braking with this setup.
radianguy
- Jan 1, 2007
thanks, this is the info I was looking for. I will give it a try!TJSHORES said:Go with the Y-P-Y spring and 14.5mm rollers with stock weights and the Back Country track. B-P-B spring will shift out to slowly. This is a great setup for a stock motor with that track. Engagement should be around 3300rpm and top end with a deep snow load should be around 8500-8600rpm. There is a hugh seat of the pants diff from low through mid band pull. Just keep in mind that you'll lose most of the engine braking with this setup.
