Need ZX2 transfer help.
zachalyse
This is in my SRX. Not many guys talking about the ZX2 over on the 2 stroke side. All I've heard is how this skid can give awesome transfer. I'm spinning and trenching like crazy! No real hook up at all. Also, Fox floats up front and having trouble getting ski pressure (carbides are doing nothing). Any help is greatly appreciated. Here is my setup:
01 SRX
1.25' ripsaw with 144 studs up the middle
09 Phazer RTX fox floats up front 75 psi ea.
ZX2 set on 2 and 5. also tried 1 and 5. Shocks on 3
weight with gear 205 lbs
Did you get the proper instaltion kit with this skid for your sled. If not then use the general instruction which were posted in this section earlier. It sounds to me that it is not installed correctly. I could be wrong. When I installed my ZX2 into my Vector had the same problem. I was sent the wrong install kit.
my expert-x was installed by Aaron Excell for my viper, transfers un-real, rips, ski's 7" off ice for a good 100 ft.
