Needed: RTX Skid mount locations
Mile9c1
Grand Rapids, MI
Hi,
Can anyone be so kind as to measure their skid mount locations (see attachment). From browsing posts I have a pretty good idea of the distances from the drive shaft to the skid shafts (assuming a 1" driveshaft which I don't know is correct), but not the actual distance between the skid shafts. FWIW, I'm trying to insall a 2009 Nytro RTX SE skid into my 2002 Viper.
TIA :)
One more question - is the skid "preloaded" when it is installed? I measure 23.75" between the front skid shaft and rear skid shaft (I think this will change a bit if the straps are adjusted). If the tunnel mounts are not 23.75" apart then the skid will have to be preloaded to bolt it up.
