new 1.5" lug track in 06 nytro
Jim yamawheels
Mequon
RX-1 mountain
We are putting a 1.5" lug track in a 06 nytro with a 136"extention on it. Does anyone know if it will rub on the front tunnel protector? Has anyone out there done this?
I ran a 1.5 on that sled. You will want to pull the tunnel protectors. But you will have about 1/8" clearance to the front cooler protectors if my memory is right.
It should work. The lug tips may slightly rub the front cooler protectors, but it'll be minimal.
I will say that if you're going to have the track out, that's a perfect time to remove the front protectors, unless you're running studs.
Thanks for your response. we do not want to pull the protectors out. If it rubs we will shave the track down.
