Rick M
- Oct 25, 2004
Ok, I got my Rage back today with Bender turbo....I am only getting 117MPH Indicated (106 actual). It seems possessed when I drive it, however it doesn't pull away from Stock RX1, did we do something wrong installing it?
It feels way more powerful, but side by side they are about even.
Switch is in high boost mode, not sure if we used right jet or not.
Rick
Rick
Thrusted Vector
The Rage is spinning wildly,check the track speed on both at the beginning of the run.
treewhacker
The turbo should spank the daylights out of the un-turboed sled. Either you're lacking transfer and traction, or you may have forgot to connect something on the turbo.
spray25
Do you have a boost and air/fuel gauge? You need to know if you are getting boost and if it is jetted right.
You should completely blow away a stock sled.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
What's the top gear in the Rage???????
kip
- Feb 22, 2004
YOU HAVE SOMETHING VERY WRONG IF YOU HAVE EQUAL TRACTION.... VERY WRONG
