ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Hey guys....
just found out some info...this might be old news as Ive been away from this site alot since last winter....
As alot of you know many of us who changed our gearing cut our clutches to get our theoretical top speed back....FIX power sports came out with a WIDE DRIVE clutch kit which works well for my buddy....
well,FIX and YAMMIE have close ties,and Yammie watched what fix was doing with there wide drive kits...and also am sure read all about us guys who werent too happy that our belts were not able to go to the top of the sheaves without machining the primary....
well...i just found out that there is a new part number for our beloved 8DN drive belts....
8DN-17641-01-00 (replaces 8DN-17641-00-00)
and sure enough,FIX tells me the new belts are 2mm wider!....which will go along way in bringing our belts to the top!.....the new belt is wide enough that FIX now will run the STOCK updated belt in their wide drive kits!....
so,anyone installing a new BELT may find they have to adjust their secondary settings so the new belt doesnt squeel(remove washers most likely)
Hope this isnt OLD news,sorry if it is.
Dan
Dan
