Snow Fever
While working on my sled I put a piece of paper towel in the inlet of my turbo to keep crap from getting in the intake track. I put everything together and started it up and it didn't want to idle or rev up. I then removed the paper towel that I had forgot and it worked much better. Brain Fart. I then took it for a ride and in an earlier post I described the way I was planning to get my Turbo to spike when you 1st hit the throttle. Well my theory was correct but I went too far........ When I hit the throtle my boost gauge pegged 15lbs (Thats as high as the gauge goes) I will have to re-think some distances on my lines but it did work. For now I will make it on the safe side until I get snow close to home for testing. Going riding Sunday if all goes well. I let you guys know how the new track works in the hills. Later SF
MadMax
Years ago I put a plastic bag over the intake tube of my wifes sled in the spring.. The following season I started it up."without thinking" Man did it run doggie.. Until it sucked the bag in.. Hmmm.. Never did get that bag out.MM.
